Unity Failover Hardware question
For configuring Unity failover, do the servers have to be identical (hardware-wise).
Navi
1 ACCEPTED SOLUTION
Re: Unity Failover Hardware question
No, they don't have to be identical but, of course, it's a real good idea that they have similiar capacities (i.e. similiar HD and port sizes). You can't go wrong using the same box for both here but as long as they are both rated for the same port/user load it'll work fine.
On a similar note I have a Cisco-branded Unity box. I am looking at failover as well but my vendor seems unable to locate a Cisco-branded Unity box for failover. He can only find the software and I would have to get an approved box. Not a huge deal but does such an animal exists or is the failover option for the software only?
91
