Unity Pin
Hello,<br><br>in an Unity 3.0 installation I have the problem that Unity tells the user that his PIN is expired. He tells the system a new pin. <br>The next times the user calls Unity he gets the message again and again. I have the same error in my test installation to.<br><br>Thanks Achim<br><br><br>
Re: Unity Pin
Just a follow up to the first reply. Although this bug was fixed in versions 3.0(3) and 3.1(2), you will not find these version on CCO. The current releases of Unity are 3.0(4) and 3.1(3). Rest assured this bug as well as many other are fixed in these builds.
Jeff Schlesser
Unified Voice Technical Lead
San Jose TAC
Gold
Re: Unity Pin
The bug ID for this is CSCdu71673. It was first resolved in the following builds of code:
3.0(3):
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_unity/unity30/rel_note/cu303rn.htm
3.1(2):
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_unity/unity31/rel_note/cu312rn.htm
Keith
Keith Chambers
Unity Technical Lead
Unified Voice Team, San Jose
Cisco Systems
100
