Unity problem
Cutomer is using Unity server as the messaging system which is integrated with NEC PBX. Recently, some users report, when outside caller trying to leave message to an extension, he got" please enter your ID" instead of the personal greet or "please leave your messgae after the tone". It looks like Unity receive a "*" sign at this point. I think the call has been transferred to extension properly, so there should be no problem with the PBX DTMF receivers and MCI/SMDI integration, since it doesn't interact with the basic call setting up.
No finding in the unity log. The next step I am going to set up the micro trace, hope can find something. Have you met this problem before?
  • Other Collaboration Voice and Video Subjects
1 REPLY
Re: Unity problem
Hello -
Although my integration experience is with Cisco CallManager and both Unity 3.1(5) and 4.0(3), by default caller input is enabled on Unity's Opening Greeting. If an outside caller hits the * key, he or she will be redirected to Signin. Could this same key be enabled for one or more of your subscribers? Check the Greetings section of your subscriber and see if #1) caller input is allowed during the greeting, and then check #2) Caller Input to see if the * goes to Signin. If your subscriber templates were based on the Example Subscriber, the default * goes to Signin. We changed our templates to have the * go to our Directory handler instead.
Ginger
87
