Unity VM volume fluctuation
When a user picks up a message (random users random messages) the voice volume will fluctuate up and down.
I am running Unity 3.1 Build 3.1(4) and a PRI to PSTN on a 3725.
If anyone has encountered this and found a fix please let me know.
Thank you,
Alin
Re: Unity VM volume fluctuation
We see a few cases on this every now and then. What version of TSP on Unity and Call Manager are you using? What are you using as a voice gateway? Have you tinkered with your input gain and output attenuation settings on the gateway?
How often does this happen? Can you reproduce it? Does this happen during regular phone conversations? Have you taken a sniffer trace of a bad call? There are audio tools out there that will allow you to strip the audio stream out of a sniffer trace and listen to it.
For an immediate workaround, make sure AGC is enabled and run the SetVolume utility. That will normalize the incoming audio.
adam
GW: PRI on a 3725 IOS 12.2(13)T with a 1T1, PRI NI2
CM (PUB/SUB) is 3.2.2c with all the updates and patches as of December.
Unity info:
Unity server name = IOGEN902
Back end is Exchange 2000
Companion Exchange Server = xxx
Unity domain =xxx
Global Catalog Server=xxx
Domain Controlers:
xxx
Unity version = 3.1(4.0)
Cisco Unity TSP version = 6.0.2.0
Exchange version = Exchange 2000 build: 5762: SP 2
SQL Version = Microsoft SQL Server 2000 - 8.00.474 : SP 1 + HF 1
Windows version = 5.0 Build 2195: Service Pack 2
Switch 0 = Cisco0002.INI
Switch 1 = Cisco0002.INI
Ports configured = 16
Default recording codec = 8K Mu-Law
TUI Languages loaded = ENU,FRA
GUI Languages loaded = ENU,FRA
TTS Default Engine = LnH
Total Subscribers = 161
Total Call Handlers = 8
Total subscribers homed locally = 161
1.I cannot reproduce the problem it happends at random times to random users.
2.It happends often enough that my users are complaining that they cannot understand their voice messages.
This just started to happen sudenly (last 3-4 weeks).
Thank you,
Alin
If this "started to happen suddenly" a month ago, then think back to what changed around then. Did you upgrade the call manager or unity server? Swap out a voice gateway? Any network changes? More phones? Anything? Stuff like this doesn't start happening on its own.
We have an audio troubleshooting guide I recommend you read through.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_unity/unity31/tsg/tsg314/tsg_0450.htm
Make sure your AGC settings match the recommendation (especially AGCsampleSize), and run the SetVolume utility.
adam
83
