09-25-2002 01:11 PM - edited 03-12-2019 08:56 PM
Unity 3.13. When I call a subscriber's mailbox, the subscriber's greeting sounds just fine. However when the female Unity voice comes on after to say " you may record your voice after the tone...." it sounds very fuzzy and crackly. It doesn't always seem to happen, just sometimes. Unity interfaces with Call Manager 3.1.3a and we use g711only.
09-26-2002 06:48 AM
When do you hear this: calling internally or from the PSTN? If it's just from the PSTN, what voice gateway are you using? If it's the 6608, take a look at this:
adam
09-27-2002 10:04 AM
We are having the same problem with the canned vioces, where as the
greetings are fine. Is does not seam to make a different if the calls
are coming from the inside or outside.
09-30-2002 11:56 AM
Sounds like CSCdx36894.
I had this problem and got a firmware load from TAC - D0040301X530 for the WS-X6608 blade. Make sure to get the DSP load for the 6608 - you should have two firmware images (guess why I know that).
That fixed it.
10-01-2002 07:25 AM
Thanks! I got the load from TAC. Did TAC explain why there is this problem? My TAC engineer didn't know anything except that it was a known bug
10-02-2002 09:01 AM
Would this work the 6625-FXS??
04-24-2003 07:17 AM
I believe it was a change in the buffer settings on the card.
