Uniy 3.0 SQL tables
What part of the subscribers info is stored in SQL. Any absract documentation in regard to what is stored in Unity DB. How do IS and DS in Exchange comunicate with SQL. <br><br>Sean Poure<br>NEC-Voice Engineering<br>Sr. Systems Engineer<br>714 4846275<br>
Sean Poure
Anonymous
N/A
Re: Uniy 3.0 SQL tables
Here’s a link to a run down on all the items stored in Active Directory for 3.0:
http://avforums.isomedia.com/cgi-bin/showthreaded.pl?Cat=&Board=unityent&Number=3942&Search=true&Forum=unityent&Words=catalog&Match=Entire Phrase&Searchpage=0&Limit=25&Old=allposts&Main=3940
this also corresponds to the same data stored in the Exchange directory for 5.5 when running 3.0. All other data is exclusively in SQL on the local Unity server. In short only information needed by other Unity servers in the organization for message addressing, address book lookups, transfers etc… is pushed into Exchange/AD in Unity 3.0.
There are a couple new processes that take care of replicating information from the local SQL server into AD/Exchange as necessary (a different process for 5.5 vs. AD) and pulling information back from Exchange/AD into SQL.
Jeff Lindborg
Unity Product Architect/Answer Monkey
Cisco Systems
lindborg@cisco.com
http://www.AnswerMonkey.net (new page for Unity support tools and scripts)
Anonymous
N/A
Is it possible to use SQL 2000 for a 12 port system (I believe the specs req 16 ports)? We want something a little bit more robust that MSDE.
Where do we get the License Key for SQL?
thanks
Anonymous
N/A
You can run SQL 2000 on any size Unity system... the option for MSDE is there merely as a cost saving mechanism for folks that don't need to high performance of the full SQL 2000 (under 16 ports). If you want to go full SQL 2000 on lower port systems, that's fine.
I can't speak to the licensing issues...
Jeff Lindborg
Cisco Systems
lindborg@cisco.com
For over 16 port systems the license is available to install it with Unity. Below that number, you will probably need to get your own copy from MS ro a reseller. Cisco does not sell licenses to MS software not bundled with standard Unity stuff.
Anil Verma
Cisco Systems
anilve@cisco.com
80
