Upgrade CCM's using spare drives
What I want to do is:
Upgrade my 3.3(2) CCM's to 4.1(3)
Can I?
Pull drive in slot 1 of publisher,install blank drive
and let the server mirror the blank drive.
Install the Drive from slot 1 into a spare server in slot 0, install blank
drive in slot 1 and let it build it.
Use spare server to upgrade to 4.1(3)
and test with a few phones. If fine, then shutdown 3.3(2)publisher and bring up new 4.1(3) publisher.
Remove subscriber from network and upgrade it to 4.1(3).
Will this work??
Re: Upgrade CCM's using spare drives
Can I?
YES
Will this work??
DOUBT IT - You will need to upgrade your subscribers after the publisher upgrade and these need to be connected to the new publisher.
Thanks.
How do I do the subscriber upgrade? Will it be okay
to leave it on the network after the new publisher is
up and running, then do the upgrade while connected?
Or should I take it off the network, do upgrade, then
bring it up.
Super Bronze
I've mirrored lots of servers this way - you've more or less got the procedure right.
You should put the disk you pull from box 1 into the same slot in box 2 though - then when you boot the second box up (presuming it's HP here) you'll need to select 'Interim Recovery Mode'. Once you've done this you're free to stick in another blank disk and the mirror will rebuild.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron,
How long will it take to mirror the empty drive? Will
it impact users?
Thanks for your help!!
127
