Community Member
Upgrade/replace phone model on CCM 4.2
I need to upgrade/replace phone model on ccm 4.2, somthing like 100 x C7905 is going to be replaced with 100 x C7940, but all other phone settings must survive transition.
What is the simplest/easiest method ? Except obvious - retyping it all manualy.
Thanx
Community Member
Re: Upgrade/replace phone model on CCM 4.2
The best solution is using the BAT tool. It is not obvious, but you'll get it.
JAVI
Hall of Fame Super Red
Hi Dubravko,
I would look into using the BAT Export utility. You should be able to edit the .csv file created from the Export, scan in the new mac's from the 7940's and then insert them in bulk. Have a look;
Working with the Export Utility
Bulk Administration Tool User Guide, Release 5.1(4)
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_user_guide_chapter09186a00803f4f29.html#wp1086410
Hope this helps!
Rob
Please remember to rate helpful posts.....
134
