02-22-2006 08:32 PM - edited 03-15-2019 04:05 AM
Hi, I am upgrading CUE 1.1.2 to CUE 2.0.2 using the boot helper. When I run the boot helper, the CUE installation file is successfully downloaded from my TFTP Server but the AIM module complains that the header is invalid.
The error message is :
Loading cue-installer.2.0.2
Dbg: Final image size: 8693083
Invalid signature hdr
corrupt dnld image
Unable to load cue-installer.2.0.2
Please check bootloader configuration using show config and verify that:
1. network connectivity to the tftp server exists and
2. the specified helper image exists on the tftp server
I am sure the file has already been transferred from the tftp server. Any help?
Thanks.
Solved! Go to Solution.
02-23-2006 12:38 PM
It's failing because of an invalid signature. Usually that means that the file on the TFTP server was corrupt in some way (maybe it was transferred incomplete; or ASCII transfer was used instead of binary somewhere along the way; etc). The best bet would be to re-download it from the cisco web site and then try booting from it again.
02-23-2006 12:38 PM
