urgent help!
hi,fr, I am a CCNP, Now I meet some trouble when we integrate voice over IP equipment, I will explain the problem in more detail.
We are a IP voice service provider, We use the "Clarent gateway" as the voice gateway, it support the "h.323", also we have cisco 3600 router and cisco As 5300(supplied with voice card).can we connect the clarent voice gateway to cisco 3600 directly (or connect to AS5300) then let the router
route the UDP packet to remote.
1 REPLY
Re: urgent help!
yes you can connect the router directly to a gateway but than it depends what kind of connection is coming in from gateway. If its T1 than u need to have t1 interface installed in your router.
regards
omair
93
