URLs available/ need to take note for CCM/UCM
Hi Experts,
Anyone can share what are the useful hyperlinks on the CCM/UCM server that need to take note in order to make configuration change?
Example will the URL for end-users to change their speed-dial, manager assistance settings, etc
Charles
Bronze
Re: URLs available/ need to take note for CCM/UCM
Charles,
I assume you are talking about CUCM 5/6/7 so here goes
CUCM admin page
https:///ccmadmin
CUCM OS Admin page
https:///iptplatform
CUCM userpage
https://///ccmuser
The user settings that the user can change are defined in the ccmadmin under System>Enterprise Parameters>CCMUser Parameters
If you are going to let users have access to the ccmadmin page suggest you set up a new user group (User Management>User Group) with limited access defined in the Role section under User Management. Apply the role to the Group using the related links drop down menu in the the User group you have created, and then add the end user to that group.
Hope this helps
Paul
Hi paul,
thanks. may i ask if these URLs are valid for cc 4.x as well?
Cos we may be using the windows platform
Bronze
Charles,
The only URL not relevent is the OS admin but the ccmadmin and ccmuser are much the same
so for 4 the recommended is
CUCM admin page
https:///ccmadmin/main.asp
CUCM userpage
http:///ccmuser
With 4 going EOL I do recommended trying to go to at least 6 and 7 if you can
Paul
Thanks for the info. :)
286
