Usage of E1 Enhanced Digital Voice Adapter for dial-in
I plan to use a 7206VXR with a PA-VXB-2TE1+
as H323 Gateway in our AVVID-Envirement.
There will be connected 2 E1/PRI to the PSTN for
in and outgoing voice-calls.
Is it possible to use some channels of the PRI concurrently e.g. ISDN-Data-connection as backup for
the the FR-PVC to the central office.
Is it possible to have different connections incoming
ISDN-Data and ISDN-Voice on the same PRI
Thanks in Advance
Hubert
  • Other Collaboration Voice and Video Subjects
1 REPLY
Silver
Re: Usage of E1 Enhanced Digital Voice Adapter for dial-in
Currently you can only terminate voice calls on the PA-VXB-2TE1 cards - they don't handle data bearercap calls.
94
