06-28-2003 11:58 PM - edited 03-13-2019 12:31 AM
What is the usage of the dual NIC on MCS 7835 ?
Which one will be connected to the LAN ?
What is the function of the second NIC ?
Mohamed Abdallah
06-30-2003 03:07 AM
Network teaming is now supported on some servers so you can use the second LAN connection for redundancy. See:
http://www.cisco.com/en/US/partner/products/hw/voiceapp/ps378/prod_installation_guide09186a008015a131.html
Hope this helps.
Justin
