Using (2) 7914s - CCME
I have several 7960's with 1 each 7914 attached that have been working fine. I went to add a second 7914, first unplugging phone and 7914, then changing config to 'type 7960 addon 2 7914', then plugged the phone back in.
Now both 7914's are blank and all red lights, in spite of multiple phone resets and power cycling and combinations of both. If I change the config back to 'addon 1' and unplug the second 7914, everything is good. When I change the config back to 'addon 2' but second 7914 is still unplugged, first one is back to all red.
Any suggestions would be appreciated.
-Michael
1 ACCEPTED SOLUTION
Re: Using (2) 7914s - CCME
Yeah, this is the correct syntax.
type 7960 addon 1 7914 2 7914
Craig
I would verify that you have the phone loads. Do you have the 7914 load specified under the telephony-service?
(7960)
tftp-server flash:P00308000400.sbn
(7914)
tftp-server flash:S00105000100.sbn
telephony-service
load 7960-7940 P00308000400
load 7914 S00105000100
ephone 1
mac-address 001A.6D0E.83CE
You can run the show ephone command to verify the phone and modules have the right load.
show ephone phone-load
Hope that helps.
Craig
So the proper syntax should be "type 7960 addon 1 7914 2 7914" as you have stated?
The syntax I am using is "type 7960 addon 2 7914"...
-Michael
Craig
Hall of Fame Super Red
Hi Michael,
Craig is correct here! 5 points for this nice answer Craig. There is a good reference in this doc;
type phone-type [addon 1 module-type [2 module-type]]
Example:
Router(config-ephone)# type 7960 addon 1 7914 2 7914
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00807e13a7.html
Hope this helps!
Rob
Hi Craig, I just tried it out and you are correct, I was using the wrong statement. Thanks a lot for your help, wish they were all that easy!!
-Michael
167
