Using C Sim Call Simulator
Has anyone used C SIM Hidden Exec command to test calls from 3845 v12.4 ?
1 REPLY
Green
Re: Using C Sim Call Simulator
Yes, it works great, here is a test:
Are you having any trouble?
AVVID4#sh ver
Cisco IOS Software, 3800 Software (C3845-IPVOICE_IVS-M), Version 12.4(7), RELEASE SOFTWARE (fc6)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 01-Mar-06 07:03 by alnguyen
ROM: System Bootstrap, Version 12.3(11r)T2, RELEASE SOFTWARE (fc1)
AVVID4 uptime is 1 day, 21 hours, 56 minutes
System returned to ROM by reload at 17:45:22 CST Mon Sep 25 2006
System restarted at 17:46:16 CST Mon Sep 25 2006
System image file is "flash:c3845-ipvoice_ivs-mz.124-7.bin"
Cisco 3845 (revision 1.0) with 481280K/43008K bytes of memory.
Processor board ID FTX0930A0D4
16 FastEthernet interfaces
2 Gigabit Ethernet interfaces
2 Channelized E1/PRI ports
6 Voice FXO interfaces
6 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
125184K bytes of ATA System CompactFlash (Read/Write)
AVVID4#csim start 917007002
548
