Community Member
Using CCM Directory between two clusters
Hi all,
In our company we have two callmanager Clusters ( Site A 4.1.3 ; Site B 6.1 )
Before we did an Upgrade on the one site we could use the directory from the other side as well as our own, but since we did the update the users can only access their own Site directory an when they try to access the other directory the phone shows a 404.
I looked at the enterprise parameters but did not find a fault, did cisco change the method of accessing the directory between the two version?
Do I have to change settings in the URL or in the XML/ASP file?
kind regards
Christian
Re: Using CCM Directory between two clusters
yes,
windows versions
http://hostname/CCMCIP/xmldirectory.asp
linux versions
http://hostname:8080/ccmcip/authenticate.jsp
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
Is there a possibility to merge/change the files so that each site can access the directory of the other side or should i wait until the old callmanager is updated in the middle of february?
139
