Using connection trunk and fxs/fxo card problems
I have two 1751V routers one with fxs card connected to CO analog port on a PBX. The other 1751 has a fxo card attached as a station to a remote PBX. The trunks set up as required and the setup will work for a while. Eventually the fxs card, specifically port 0 will ring incessantly. Despite an off-hook condition, as soon as the call is answered and hung, the ringing starts again. Software is 12.1(5)YB4.
pending case C163691
1 REPLY
Anonymous
N/A
Re: Using connection trunk and fxs/fxo card problems
Two things are wrong with this soultion
1. the fxsport only supports analogue phone connection. You
cannot connect it to the pbx CO port. What you've done is the pbx is
suppose to be or simulate a phone which makes
and receives phone calls.
2. with trunking between the ports, whenever the remote fxo
goes off-hook, the fxs port its being
trunked to would ring. Trunking simulates a physical
wire between fxs-to-fxo.
a)The phone would always ring if the fxo goes off-hook.
b)The fxs port ca go off-hook and it would play a dialtone sourced
from the remote fxo, it cannot collect the digit inputed by the PBX, the remote
fxo-pbx connection port would be responsible for that.
The is fsx-to-fxo trunking should e used for a phone line extention to
a remote site, i.e PBX1--fxo--voip--fxs--phone. logically the phone
is connected to PBX1.
248
