Using fax on ViewMail Outlook
I learned that we can read fax on Outlook so how people can send fax to us ? using my desk phone number ? please help to understand how it works. Thank you very much.
Duc Vu
Re: Using fax on ViewMail Outlook
We do not do this today in Unity and I do not know of anyway that it can be done today using your phone number. We have many 3rd party fax vendors we work with today and they are documented on CCO so you can check them out. Basically their server recieves the messages and then depending on vendor (on how) it gets sent to your exchange inbox where VMO displays it as a fax.
actually... to be clear, VMO does not come into play for faxes in your inbox... the VMO form only triggers on messages that have a message class of IPM.Note.Voice.Unity. Faxes will have whatever message class the 3rd party fax server sticks on them and Outlook will use whatever form is appropriate (usually just the regular email form unless your fax server comes with custom forms you can install in Outlook).
86
