Using FXO ports for SRST on a 2621. Is it possible to configure a dial peer hunt group ?
In FXO ports for SRST on a 2621 , configuring a dial peer hunt group is possible?
How to configure the router to cycle through the FXO ports until it finds one that is not busy?
1 REPLY
Anonymous
N/A
Re: Using FXO ports for SRST on a 2621. Is it possible to config
Yes, Configure the same destination pattern on the dial-peer for the all voice port.
Use the voice hunt user-busy command and the dial-peer would be hunted if a port is busy. This is usually in any order
mostly top/down but you can use the preference command to
switch hunting to the order preferred.
127
