Community Member
Using QoS-groups with 802.1q/p
I was wondering if anyone had come across this problem.
I have configured qos-groups on a router. The qos-group matches on mpls exp-bit 4 on the input interface and sets CoS 4 (802.1p) frames on the output sub-interface.
The problem lays with the downstream router. The router isn't recording the frames as being ,marked with CoS 4. I am using extended pings to generate the traffic across the router. A network sniffer is also observing the the frames with CoS value 0.
Any recommendations?
The configurations are shown below:
Upstream router:
class-map match-all qos_group_4
match qos-group 4
class-map match-all mpls_voice
match mpls experimental 4
policy-map ethernet_trunk_out
class qos_group_4
set cos 4
policy-map ethernet_input
class mpls_voice
set qos-group 4
Downstream:
class-map match-all cos4
match cos 4
policy-map ethernet_trunk_in
class cos4
police 8000 1500 1500 conform-action set-mpls-exp-transmit 4 exceed-action
1 REPLY
Bronze
Re: Using QoS-groups with 802.1q/p
I don't see the downstream router configured for Policy map on the interface. Hope you have applied the policy map on the incoming ethernet interface of the router.
114
