I'm not sure why it should have kept disappearing in and out like that but you should check your route patterns. Are they defined (9.1! etc.) or are they using 9.@.
if it's the first then check that there is a # version of the route pattern so 9.1! and 9.1!#.
If it's 9.@ then it has anybody changed the NANP file between version.
Paul
