v214 phone load
I'm setting up Informacast from Berbee, and they recommend using phone load (firmware) version 214 on 7960 phones. We've got version 209 currently installed. I found the release notes for v214, but can't find where to download it from. Anyone ideas?
Thanks, Karim
1 ACCEPTED SOLUTION
Re: v214 phone load
Karim,
Are you after the P00303020214 load? if so, the file name is actually cmterm-7940-7960.P003-3-2-5.exe and you can get it below:
http://www.cisco.com/cgi-bin/Software/Tablebuild/doftp.pl?ftpfile=cisco/voice/ip-7900ser/cmterm-7940-7960.P003-3-2-5.exe&swtype=FCS&software_products_url=%2Fcgi-bin%2Ftablebuild.pl%2Fip-7900ser&isChild=&appName=
cheers
1 REPLY
Re: v214 phone load
Karim,
cheers
93
