Valcom Paging lockups
We've implemented valcom overhead paging for a customer -- works great, except... Every now & then someone will page and then not hang up (or hang up wrong) -- and it keeps paging locked up so no one else can use it -- worse, they end up broadcasting their conversations over the speakers. Eventually, the FXO port locks up so that even if they do hang up, the FXO port never hangs up. Resetting the FXO port or the gateway itself works, but the customer has no access to the gateway (well, except the ONOFF switch). Has anyone else had this problem & how was it solved? Is there someway to time limit a paging session -- the gateway is a H.323 gateway (1760 with a vic2fxo).
Thanks!
John
1 REPLY
Re: Valcom Paging lockups
You can use a tcl script to automatically disconnect the call after a maximum connect time.
PL
250
