Community Member
Valcom V-2904 Answering System Problem
Cisco 2800 series router with 7940 series phones.
Trying to connect a Valcom V-2904 system into existing VOIP network. Configed dial-peer voice pots able to connect to all door answering systems without any problems (Phones to doors).
My problem is when someone presses the remote push button none of the phones are ringing.
When I bypass the Cisco & connect the Valcom directly to an analog phone it works.
I beleive I'm having a voice-port config. issue.
If someone could copy a working config for this problem I would be greatful.
Re: Valcom V-2904 Answering System Problem
In your voice port config do you have connection plar opx XXXX?
You also need VOIP dial peers to send the call to the Call Manager.
Community Member
Yes, my config looks like this
voice-port 0/2/3
translation-profile outgoing SRST
ring number 2
no vad
no comfort-noise
timing hookflash-out 500
timing inter-digit 50
connection plar opx 6212
station-id name line 12
station-id number 6212
caller-id enable
dial-peer voice 40 pots
destination-pattern 2
port 0/2/3
ephone-dn 81
number 6212
label Line 12
description Line 12
name Line 12
preference 1 secondary 1
hold-alert 30 shared
