I have the following problem, and I don't know it is it a router or pbx problem. I have 2 1750-2V with 1 FXS and 1 E&M. I configure a variable
length dial plan for example :
dial-peer voice 7 pots
destination-pattern 9T
port 0/1
forward-digits 7
prefix ,,99,9
so I can dial 91900, or 96224242. If I dial 9 and then 7 digits it run OK, but with less digits no. I can see that the destination router receive the digits correctly, so I think that the router sends wrong digits to the PBX, or the PBX perhaps don't understand them. Do you have any idea ??
Thanks a lot for your help!
Regards, Anacelia
