05-31-2002 10:54 AM - edited 03-12-2019 07:03 PM
Hello Everyone,
Has anybody used the VG-200 for Faxing and had good Results.
We are trying to roll it out in our network but our testing still show inconsistant
faxing results. We are trying to use the 4 FXS ports to hook up 4 fax machines to service 4 (BUSY) offices. They average 150+ faxes a day.
I would like some feedback on how the success of lack there of , on implementing the VG-200 as a Fax Gateway Solution.
thank you in advace for all your comments and suggestions.
Pablo
05-31-2002 12:02 PM
We had quite a bit of trouble with ours at first but they work fine now. two problems;
1) we had to use IOS Version 12.1(5)XM4
2) disable MGCP
stephen
06-05-2002 02:44 PM
We have been very stable for over a year and half.
vg-200 4 fxs ports
ver 12.2.6
running gateway as H323
downside you have to create route patterns for each specific fax number and then route them to that gateway. we arent ready to change over to MGCP after what has been seen in the forums.
