VG 248 not booting normal
Im having issue with our VG 248 Voice Gateway. This has been working for the pass couple of years now and all of a sudden the link starts to flap. We have change both cables and switch ports and it is still the same.
When I restart the gear with console cable to monitor the POST, this is what I get:
Cisco DAVROS Boot Loader
Copyright (c) 1999-2001 Cisco Systems, Inc.
All rights reserved.
Testing RAM.........passed
Version 1.0(1).
Decompressing image .........completed
Launching phase-2 boot image.........success
Testing FLASH.......passed
Testing EEPROM......passed
Testing Ethernet....passed
Pausing for FTP.....press Escape for boot loader menu
Info: Running Core
Info: Loading modules now...
Info: Loading and exporting module xml.mod
Info: Loading and exporting module configxml.mod
Error: Ethernet failed to start
Info: Loading and exporting module country.mod
Info: Loading and exporting module corex.sys
Info: Loading and exporting module snmp.mod
Info: Loading and exporting module gccs.mod
Info: Loading and exporting module slic.mod
Info: Loading and exporting module chorus.mod
I shut down the Ethernet to isolate the problem and it looks like this device is getting the config from another device via TFTP. When I re-enable the switch port, the boot is the same:
Version 1.0(1).
Info: Running Core
Pressing escape doesn't do much as it takes me to boot loader menu use for Password Recovery or network config. Then loops back to the POST screen.
http://www.cisco.com/en/US/products/hw/gatecont/ps2250/products_password_recovery09186a008009440c.shtml
Any ideas?
Peter
1 REPLY
Silver
Re: VG 248 not booting normal
The Ethernet cable may not properly connected to the VG248 or to the hub or switch. Check the Ethernet cable and reconnect it to the VG248 and the hub or switch. If error persists, replace cable.
Troubleshooting the VG248:
http://www.cisco.com/en/US/docs/voice_ip_comm/vg248/1_1/english/configuration/guide/vg248swt.html
330
