Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
VG200 as MGCP for T1 PRI
Hi!
I am trying to use Vg200 to connect to PSTN thru a T1 PRI ISDN connection.I want to use MGCP for this purpose instead of H.323 .My VG200 is 12.2(2)XN IOS.
I want to use my T1 for both incoming and outgoing calls.Do any one has a configuration for this that works.My eamail is uttaranc@att.com
Thanks in advance
regds
Uttaran
Re: VG200 as MGCP for T1 PRI
Uttaran,
Have you read the configuration guide for the new feature in 12.2(2)XN? It is pretty helpful, and also explains how to configure the VG200 to get its configuration from the CallManager automatically.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122limit/122x/122xn/122xn2/ft_ccm.htm
Thanks Dave
That helps..
97
