vg200 will not register in ccm 3.22c
I am installing a vg200 version 12.2.15t. I have an nm-hdv module with a vwic-2mft-t1-d1 card in it. The router will not regiser with callmanager. The ccm shows the correct ip address but it will not register. I have triplechecked my hosts file to verify that the mgcp-domain name that I have input into ccm is pingable and exact to the hostname in the vg200. As the "show ccm" will speak too, it would seem that connectivity is there.
MGCP Domain Name: cleve-vg200
Priority Status Host
Primary Registered 10.235.0.3
First Backup Backup Ready 10.235.0.2
Second Backup None
Current active Call Manager: 10.235.0.3
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 00:01:57 UTC Mar 1 1993 (elapsed time: 00:00:07)
Last MGCP traffic time: 00:01:57 UTC Mar 1 1993 (elapsed time: 00:00:07)
Last failover time: None
Last switchback time: None
Switchback mode: Graceful
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
PRI Backhaul Link info:
Link Protocol: TCP
Remote Port Number: 2428
Remote IP Address: 10.235.0.3
Current Link State: OPEN
Statistics:
Packets recvd: 0
Recv failures: 0
Packets xmitted: 4
Xmit failures: 0
PRI Ports being backhauled:
Slot 1, port 0
Configuration Auto-Download Information
Current version-id: {2182E3AB-11D6-4D18-81AC-8A67555C1201}
Last config-downloaded:00:00:25
Current state: Waiting for commands
Configuration Download statistics:
Download Attempted : 1
Download Successful : 1
Download Failed : 0
Configuration Attempted : 1
Configuration Successful : 1
Configuration Failed(Parsing): 0
Configuration Failed(config) : 0
Last config download command: New Registration
Configuration Error History:
controller T1 1/0
controller T1 1/0
controller T1 1/0
controller T1 1/0
controller T1 1/0
controller T1 1/0
FAX mode: cisco
here is my show run
cleve-vg200# show run
Building configuration...
Current configuration : 1620 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname cleve-vg200
logging queue-limit 100
voice-card 1
ip subnet-zero
ip tcp synwait-time 13
isdn switch-type primary-ni
no voice hpi capture buffer
no voice hpi capture destination
mta receive maximum-recipients 0
ccm-manager redundant-host 10.235.0.2
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.235.0.2
ccm-manager config
controller T1 1/0
framing esf
linecode b8zs
cablelength short 133
pri-group timeslots 1-24 service mgcp
controller T1 1/1
framing sf
linecode ami
interface FastEthernet0/0
ip address 10.235.0.9 255.255.0.0
speed 100
full-duplex
h323-gateway voip bind srcaddr 10.235.0.9
interface Serial1/0:23
no ip address
no logging event link-status
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
ip classless
no ip http server
call rsvp-sync
voice-port 1/0:23
mgcp
mgcp call-agent 10.235.0.3 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
no mgcp explicit hookstate
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 1 pots
application mgcpapp
port 1/0:23
line con 0
line aux 0
line vty 0 4
login
end
1 REPLY
Re: vg200 will not register in ccm 3.22c
1. debug mgcp packet and see if the registration was completeted with no error
2. The sh ccm call manager shows the gateway is currently registered to 10.235.0.3
3. what is the state of the gateway in the ccm admin page.
4. despite the state of the calls above, can you make and receive calls via the gateway
5. no ip domain-lookup and no ip domain-name should be configured on the gateway. if you're not referencing the fully qualified domain name in Call manager admin page.
Let me know what happens, I have a similar issue reported to me this morning by a collegue
Tola.
82
