VG200 with FXO
Using CCM 3.1.2(c) and VG200 MGCP 12.2.4T code, I hear an echo during the first word spoken with PSTN calls. After the initial echo everything is fine. Any ideas?
Re: VG200 with FXO
I think you are running into CSCdv66278. You should probably open a TAC case, mention this DDTS number and see what they can do for you.
Re: VG200 with FXO
What do you mean by this. Is it a hardware issuse or a software problem?
Re: VG200 with FXO
Software problem if my thinking is correct. The id number I gave you is a bug reference number you can give to TAC so they can investigate your situation further and see if it is related.
Re: VG200 with FXO
Can you give any detail of the bug id? I tried looking it up but it looks as if the information is not public. Is there any known fixes for the bug?
90
