VG200 with PRI and Call Manager
Hi there,
I am having a problem to make out bound or getincoming calls via my VG200 Gateway.
Guys this is the first time I am trying this, and using MGCP so I am lost, I had a look at http://www.cisco.com/en/US/tech/tk652/tk701/technologies_configuration_example09186a00800c3246.shtml (How to Configure MGCP with Digital PRI and Cisco CallManager) but it is not helping me much.
When I phone the Primary number, I don't get dial tone or anything, it seems to go though, its quite for a few seconds, and then the phone gives me a busy tone too,
Ok here is my configuration.
My CCM IP is 10.1.1.10
My VG200 Gateway is 10.1.1.11, it has a NM-HDV with Sub Unit VWIC-1MFT-E1 PRI card in it
IP Phone is 10.1.1.12 with Number 2001
This is my configuration from my VG200
Router_A_vg200#show run
Building configuration...
Current configuration : 1488 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Router_A_vg200
enable password cisco
voice-card 1
ip subnet-zero
no ip domain-lookup
mgcp
mgcp call-agent 10.1.1.10
mgcp dtmf-relay codec all mode out-of-band
call rsvp-sync
isdn switch-type primary-net5
voice class codec 1
voice class h323 1
h225 timeout tcp establish 30
ccm-manager switchback graceful
ccm-manager mgcp
controller E1 1/0
pri-group timeslots 1-31
description Net5 link to PSTN
interface FastEthernet0/0
ip address 10.1.1.11 255.255.255.0
no ip mroute-cache
speed 100
full-duplex
interface Serial1/0:15
no ip address
no logging event link-status
isdn incoming-voice voice
isdn T309-enable
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.1.1
no ip http server
ip pim bidir-enable
voice-port 1/0:15
timeouts interdigit 2
dial-peer voice 1 pots
application mgcpapp
destination-pattern 0...
direct-inward-dial
port 1/0:15
forward-digits all
dial-peer voice 7 pots
destination-pattern 7T
port 1/0:15
forward-digits 0
dial-peer voice 2001 voip
destination-pattern 2001
session target ipv4:10.1.1.10
ip precedence 5
gateway
On my Call Manager I set my Route pattern as follows
Route pattern : 7.@
Gateway/ Route List : S1/DS1-0@10.1.1.11
Discard Digits : PreAt
Silver
Re: VG200 with PRI and Call Manager
Can you post sh ccm an sh mgcp from the vg200?What happens to the outgoing calls?What is the ios version?
In general your pots dial-peer (only one per pri!!) is controlled by the callmanager and should be configured like that
application mgcpapp
port 1/0:15
And your controller settings are wrong..
Here is the working configuration for you...(also verify if the framing is crc4 or no-crc4 with pstn..)
configuration : 1701 bytes
version 12.2
no parser cache
no service single-slot-reload-enable
no service pad
hostname test
logging rate-limit console 10 except errors
voice-card 1
ip subnet-zero
no ip dhcp-client network-discovery
mgcp
mgcp call-agent 10.1.1.10 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode cisco
mgcp sdp simple
mgcp package-capability rtp-package
mgcp package-capability sst-package
no mgcp timer receive-rtcp
no mgcp explicit hookstate
call rsvp-sync
isdn voice-call-failure 0
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.1.1.10
ccm-manager config
controller E1 1/0
framing NO-CRC4
pri-group timeslots 1-31 service mgcp
duplex auto
speed auto
no ip address
isdn overlap-receiving
isdn bind-l3 ccm-manager
isdn sending-complete
no cdp enable
ip classless
no ip http server
voice-port 1/0:15
application mgcpapp
port 1/0:15
line con 0
line aux 0
line vty 0 4
I dont like the discard digits preAt as well, predot is much better
I have changed most of my configuration to be simlar to yours. as well as putting only one pots dial-peer in. as well as changed my call manager to be predot.
Here is my sh ccm
Router_A_vg200#sh ccm
MGCP Domain Name: Router_A_vg200
Total number of host: 1
Priority Status Host
Primary Registered 10.1.1.10
First backup Undefined
Second backup Undefined
Current active Call Manager: 10.1.1.10
Current backup Call Manager: None
Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 1d23h (elapsed time: 00:00:27)
Last MGCP traffic time: 1d23h (elapsed time: 00:00:13)
Last switchover time: None
Switchback mode: Graceful
and sh mgcp
Router_A_vg200#sh mgcp
MGCP Admin State ACTIVE, Oper State ACTIVE - Cause Code NONE
MGCP call-agent: 10.1.1.10 Initial protocol service is MGCP
MGCP block-newcalls DISABLED
MGCP dtmf-relay codec all mode out-of-band
MGCP modem passthrough: CA
MGCP request timeout 500, MGCP request retries 3
MGCP gateway port: 2427, MGCP maximum waiting delay 3000
MGCP restart delay 0, MGCP vad DISABLED
MGCP simple-sdp ENABLED
MGCP undotted-notation DISABLED
MGCP codec type g711ulaw, MGCP packetization period 20
MGCP JB threshold lwm 30, MGCP JB threshold hwm 150
MGCP LAT threshold lwm 150, MGCP LAT threshold hwm 300
MGCP PL threshold lwm 1000, MGCP PL threshold hwm 10000
MGCP playout mode is adaptive 60, 4, 200 in msec
MGCP IP ToS low delay disabled, MGCP IP ToS high throughput disabled
MGCP IP ToS high reliability disabled, MGCP IP ToS low cost disabled
MGCP IP precedence 5, MGCP default package: line-package
MGCP supported packages: gm-package dtmf-package trunk-package line-package
hs-package rtp-package
I have added the VG200 as an MGCP gateway in the call manager as a Cisco VG200 gateway type, and Device protocol = No Required for MGCP, thats the o
When I call from the VoIP side, I get no events, it is as if the Call manager is not sending anything to the gateway.
I have put a debug on MGCP events on when I call from the PSTN here it is
1d23h: mgcpapp_process_ccapi_ev: CALL_SETUP_IND
1d23h: callp : 815484D8, state : 0, call ID : -1, event : 10, minor evt: -213542
5024
1d23h: MGCPAPP state machine: state = 0, event = 10mgcp_process_off_hook:
1d23h: process_det_mgcp_offhook(): callp=815484D8
1d23h: process_event_actions(): callp=815484D8, sig_q 0
1d23h: send_mgcp_notify_msg, voice_if 811C01B4, obs_evt_q_ptr 81547338, endpt S-
32745/DS1-0/2@Router_A_vg200setup_ipsocket: laddr=10.1.1.11, lport=2427, fa
ddr=10.1.1.10, fport=2427
1d23h: mgcp_enq_retx_msg:, voice_if 811C01B4, trans_id 15789, ntfy_ent
1d23h: send_mgcp_notify_msg NTFY Packet sent successfully - S-32745/DS1-0/2
1d23h: mgcp_enable_det_evt_list
1d23h: callp : 815484D8, new state : 1, call ID : 26
Entered mgcp_retx_msg
1d23h: Retx msg:notify_entity=,raddr=10.1.1.10,rport=2427, first_retx=1
1d23h: Retransmit msg to raddr=10.1.1.10,rport=2427 from laddr=0.0.0.0,lpor
t = 0setup_ipsocket: laddr=10.1.1.11, lport=2427, faddr=10.1.1.10, fpo
rt=2427
1d23h: mgcp_retx_msg: SUCCESSFUL retransmission
1d23h: retx msg again, retx_cnt=1
1d23h: MGCP Process timer Complete:Entered mgcp_retx_msg
1d23h: Retx msg:notify_entity=,raddr=10.1.1.10,rport=2427, first_retx=0
rt=2427
1d23h: retx msg again, retx_cnt=2
rt=2427
1d23h: retx msg again, retx_cnt=3
1d23h: MGCP Process timer Complete:MGCP sys msg: (13, 0)
xlate sys msg: (13, 81546590)
sys msg values: (13, 8, 1, 0)
1d23h: CMAPP: process mgcp_handle_cmapp_event
1d23h: CMAPP: mgcp_cmapp_send_keepalive: cm_ipaddr=10.1.1.10 cm_port=2427
1d23h: CMAPP: notify_entity=10.1.1.10:2427
1d23h: gateway host is Router_A_vg200
1d23h: CMAPP: mgcp_cmapp_send_empty_notify_msg: voice_if 80DD93E8, complete_endp
t *@Router_A_vg200setup_ipsocket: laddr=10.1.1.11, lport=2427, faddr=10.1.1.10, fport=2427
1d23h: mgcp_enq_retx_msg:, voice_if 80DD93E8, trans_id 15790, ntfy_ent
1d23h: mgcp_cmapp_send_empty_notify_msg NTFY Packet sent successfully - *Entered
mgcp_retx_msg
rt=2427
rt=2427
rt=2427
1d23h: Retransmission Counts exceed. No alternate IP Addresses available.
1d23h: callp : 815484D8, state : 1, call ID : 26, event : 11, minor evt: 74
1d23h: MGCPAPP state machine: state = 1, event = 11
1d23h: mgcp_process_on_hook: callp=0x815484D8 call_id=26
1d23h: process_det_mgcp_media_event: callp=815484D8, major_ev_t 12, minor_ev 74
1d23h: mgcp_process_detected_evt: callp=815484D8, event=74 persistent_evts=FALSE
1d23h: mgcp_process_detected_evt: callp=815484D8, event=74 persistent_evts=TRUE
1d23h: mgcp_cleanup_media_evt_lists
mgcp_delete_req_digit_filter_q
mgcp_delete_qb_evt_q:cleanup QB evt q
1d23h: mgcp_disconnect_call_leg O.K. call_id=26
1d23h: callp : 815484D8, new state : 6, call ID : 26
1d23h: callp : 815484D8, state : 6, call ID : 26, event : 8, minor evt: -2135425
024
1d23h: MGCPAPP state machine: state = 6, event = 8
1d23h: mgcp_call_disconnected: callp=0x815484D8 call_id=26
1d23h: mgcp_call_disconnected: voice_if->ntfy_queue=811C01D8, ntfy_qhead=0, ntfy
_qtail=0
1d23h: callp : 815484D8, new state : 0, call ID : -1
xlate sys msg: (13, 814775E0)
Here is a trace on h.245 debug.
This is when I phone from the PSTN into the gateway, Could this mean that there is a problem with my Configuration of the call manager, and not the gateway ??? Cause from this what I think I see is that the Gateway sends the messages, but the call manager does not accept it ??? Am I wrong ???
Router_A_vg200(config)#Changing to new event: CONNECT
h323chan_chn_connect: connecting to 10.1.1.10:1720
2d18h: h323chan_gw_conn: connect in progress on socket [1]h323chan_chn_con
nect: using fd 1, owner_data(ccb) 0x811CBA40
changing from NONE state to CONNECTING state
h323chan_chn_process_read_socket: fd (1) of type CONNECT_PENDING has data
Changing to new event: CONNECTED
changing from CONNECTING state to CONNECTED state
Hex representation of the SETUP TPKT to send.030000C0080200060504039090A37005813
23030317E00A8052080060008914A00020880013C050100002B7277B3171D11CC8068B4EE0E1B7C7
300451C0700C40FDC7B414611002B7277B3171D11CC8069B4EE0E1B7C733202120000000D4001800
A04000100C40FDC7B45811D400000060401004D4001801114000100C40FDC7B458000C40FDC7B458
10100010006A001002D0140B500001226E001010001A116A104039090A31803A9838E1E028483700
58133353030028006000400000003
2d18h: h225SetupRequest: Q.931 SETUP sent from socket [1]h323chan_chn_process_re
ad_socket: fd (1) of type CONNECTED has data
2d18h: H323chan Lib: No Data on socket [1]:
PROCESS_READ: NOT COMPLETE, rc 10, fd=1
h323chan_chn_process_read_socket: fd (1) of type CONNECTED has data
2d18h: h323chan_recvdata:Connection lost socket [1]
2d18h: h323chan_close: TCP connection from socket [1] closedh225TerminateR
equest: Unidentifiable socket -1
Silver
The show ccm output you posted does not show all the info, could you post the full output,please? The second part of it would show us the config downloading information .
On the gateway configuration page, what is the gateway's registration status?
It looks to me as there is something wrong with callmanager configuration.
Another thing to verify is vg200 host name should match the gateway name that is specified in the CallManager configuration (Router_A_vg200 in your case).Can you try to ping vg200 from the callmanager and if you can't ping it by the hostname ,please add the hostname to the hosts file..
When you add the VG200 as a MGCP gateway to CallManager you must enter it with the exact name (no IP address) of the router - in your sample config this was "Router_A_vg200".
If you have an "ip domain ...." statement configured on the router this must be appended too - the gateway name in CallManager would then be " Router_A_vg200.domainnamesample.com". You will then need to rework the route pattern.
A "show ccm-manager" will tell you if the gateway is registered, along with looking at the MGCP endpoints info on the gateway config in Callmanager.
Good luck... Phil.C
364
