VG224 dual protocol MGCP and SCCP
echaubet
Hi all,
i would like to use my VG224 with phones and Fax. The problem is that i need supplementary services for the phones so i will use SCCP. In SCCP fax are not suported so i need MGCP but i loose my suplementary services. Do you know if it is possible and supported to mix the port configuration with SCCP and MGCP on the same GW.
cwatts
I have not used this in production yet, but in my testing environment, a VG224 with a mix of SCCP-controlled ports and H323-controlled ports works fine.
