VG224 fax issue
Analog Phone->VG224(MGCP)--CCM4.1(3)--3725(MGCP)--PSTN
Analog works fine, can dial any PSTN number and from the PSTN can the analog phone. But when I connect a fax machine to the VG224, and try from IP Phone dial the fax number, there is no fax dial tone. When I try to send a fax, I can hear remote site site sending fax tone, and then about 10 seconds later the fax get comm error.
eptpos does not work either when connecting to VG224.
Here is the related configuration:
version 12.4
voice-port 2/0
echo-cancel coverage 32
cptone AU
timeouts call-disconnect 5
timeouts ringing 360
timeouts wait-release 5
impedance complex1
ccm-manager fallback-mgcp
ccm-manager redundant-host X.X.X.X
ccm-manager mgcp
ccm-manager config
mgcp
mgcp request timeout 2000
mgcp call-agent 10.103.0.132 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp modem passthrough voip codec g711alaw
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp timer receive-rtcp
mgcp sdp simple
no mgcp fax t38 ecm
mgcp fax t38 inhibit
mgcp profile default
dial-peer cor custom
dial-peer voice 200 pots
service mgcpapp
destination-pattern 8001
fax rate disable
direct-inward-dial
port 2/0
forward-digits all
Appreciate any advice.
335
