VG248 Analog Gateway Cabling
Can someone tell me which Cables (with Part No.) can be used to connect analog phones/fax to the VG248 Gateway?
1 REPLY
Bronze
Re: VG248 Analog Gateway Cabling
You must use the standard RJ-21 Category 5 telco connector and cable to connect to the female RJ-21 connector of the VG248. Each of these cable will support upto 24 analog lines.
More details on this cable is available in one of Cat6K document
http://www.cisco.com/en/US/products/hw/switches/ps708/prod_module_installation_guide09186a00801787ab.html#22648
129
