VG248 and Credit Card Machines
We have installed a set of VG248's for a customer and things are generally working fine but for a problem with their credit card machines. The problem seems to be that they will make multiple calls for a credit card authorization before it finally seems to get everything working. Most of the time this is not a problem in that the amounts that are put on hold with the credeit card company are small and are reconsilled that night.
Has anyone else seen problems with credit card machines connected to VG248's?
1 REPLY
Blue
Re: VG248 and Credit Card Machines
I have. What is the baud rate of the credit card machine? Are you having any other issues with you faxing or modems connected to this VG248. What type of fax mode are you using on your gateway?
164
