Blue
VG248 and Modem Issues
I have verified that my MGCP setup matches the setting outlined by Dave. The one thing I did not check earlier was the "Passthrough Signalling" setting. It was set to "legacy". Upon changing this things got even worse. I was just curious as to why. Here is my setup:
- 4604AGM - 2 PRI's
- ECAN Disabled on VG248 Modem ports
- Fax Relay disabled on all VG248 ports
- The commands below are configured on the gateway
- no ccm-manager fax protocol cisco
- mgcp modem passthrough voip mode nse
Speed/Duplex Hard Coded on each side (switch interface is clean)
- QOS is properly configured everywhere on the network according to AVVID guidelines
- ERL Levels are at an acceptable level on the gateways
- Layer 1 issues have been checked out.
- Version 1.2.1 on VG 248
- Version 12.2(15)T8 on AGM
- Show controllers T1 on the PRI's shows no linecode violations or slips
- ccm-manager config portion
ccm-manager redundant-host x.x.x.x
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server x.x.x.x
ccm-manager config
- mgcp configuration
mgcp
mgcp call-agent x.x.x.x 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
</b>mgcp modem passthrough voip mode nse</b>
mgcp modem passthrough voip codec g711alaw
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp bind control source-interface Loopback0
mgcp bind media source-interface Loopback0
mgcp rtp payload-type g726r16 static
<font color="red"><Cut From Dave Goodwin Post></font>
4. IOS for 17xx/26xx/36xx/36xx = 12.2(15)T8. To configure fax and modem passthrough for H.323, use:
voice service voip
fax protocol pass-through g711ulaw
modem passthrough nse codec g711ulaw
To configure fax and modem passthrough for MGCP, use:
5. VG248 software = 1.2(1). To configure fax passthrough, set the Telephony Port Specific Parameters for each desired port for Fax Relay (disabled). Also set the Telephony Advanced Settings for Passthrough signaling to (IOS mode).
1 REPLY
Re: VG248 and Modem Issues
Based on the information you have given, I think you will need to open a Cisco TAC case. The engineers at the Technical Assistance Center will be able to help you with this.
201
