Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
VG248 MSG waiting indicator not working with Unity VM
We have a VG248 connected to call manager 3.3 and Unity 4.O.. Calls to the VG248 ports connect as expected to Unity, but MSG waiting indicator or stutter does not activate even though programmed in CM. MSG waiting works fine on the IP sets. What am I missing here? Thanks for any suggestions...
Re: VG248 MSG waiting indicator not working with Unity VM
That's not going to work.
This is the config supported
CCM <--> TSP <--> UNITY
CCM <--> VG248 <--> LegacyVM system
I found the problem,,, Call Manager was not setting the port for message waiting lamp/stutter... I had to telnet into the VG248 and set the port. Now it works,,,
104
