VIC-BRI Issue
Hello.
I have an 2621 as a H.323 Gateway with an VIC-2BRI connected to one of those equipments to make calls to mobile phones in order to reduce charges.
It all works fine for a while but then, after a brief period of time, the router stops making calls through the VIC-2BRI.
The reason that the router shows is "no circuit" and if I do a show isdn status, I see 0 Layer 3 active calls but strangely I've also got CCBs allocated, in spite of no active calls!
If I clear the interface it goes back to normal for another period of time.
Any sugestions? thank you!
Bronze
Re: VIC-BRI Issue
Looks like a bug to me. Would suggest you to look for any known issues through the CCO Bug toolkit.
Re: VIC-BRI Issue
I did. There's kind of a similar bug but for the as5300. I also suspect of a bug so I guess my only chance is the TAC... thanks for the suggestion.
76
