VIC2-2BRI problem
I need help regarding problem i'm having with ISDN BRI cards.
The problem is from time to time L1 link goes down between PBX and Cisco 2801 with VIC2-2BRI cards. Problem is not related to a specific type of PBX or just one PBX, but this happens very frequently now, on multiple sites.
I've managed to find several workaround solutions, but they are far from final.
1. If i'm using new cards (BRI) and setting a new site, I can't get the cards to go up, that is OK light won't come up, unless I connect straight cable in BRI card, and on the other side connect (short circuit) pins 3,4 and 5,6, make a loop. And here is the "tricky" part, if I don't do shut, no shut cards won't come up, or reload the router and connect cable to card before interfaces come up.
2. On existing sites link just goes down, all by itself, in that case all that helps is to put the cards in another slot, and use the above method. Cables stay the same, cards and router also, IOS also.
I really don't see the problem here!
Has anyone had any similar experiences?
Damir
Re: VIC2-2BRI problem
Is the PBX set to bring layer 1 down during periods of inactivity? If you make a call from the PBX into the router does Layer 1 come up?
-Felipe
No I have few locations that function in that way, but here this is not the case.
If i debug on layer 2 debug isdn q921, i can only see messages from the router to PBX, not other way around.
Damir
Damir,
Can you provide debugs that show the transition from a working to non-working state? How long does it take to reoccurr? I've seen similar issues when there is a interop issue between the BRI interface and the BRI modem.
-Felipe
Unfortunately, I don't see the actual transition, it would help me also.
This is only thing i've found in logs.
Nov 18 10:49:47: ISDN BR0/2/0 **ERROR**: handle_l2d_srq_mail: Layer 1 inactive
Nov 18 10:49:50: ISDN BR0/2/0 Q931: L3_ShutDown: Shutting down ISDN Layer 3
Nov 18 10:49:51.042 CET: %LINK-3-UPDOWN: Interface BRI0/2/0, changed state to down
But from this I can't see that much...
Thing is this happens more when you are using new cards, or existing somewhere else.
Normal cards light up OK when they are going through POST, it tells you that the card is recognized and working. B1 and B2 channels (lights) don't light of course.
More and more I think this a bug...
P.S. sorry I can't provide more errors, but this is only thing that happens, that's way it's strange!
Damir
If you'd like to test the card, create a BRI crossover cable and connect the two ports back to back. Instructions on how to create the cable and the configuration can be found in the following document.
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_configuration_example09186a008010ef6c.shtml
-Felipe
Hi Felipe,
I've already tried that, and the card is ok...
Damir
Damir,
The next step is to setup debugging to capture when the issue occurs.
I would advise using a local syslog server and collect the following debugs,
debug isdn q921
debug isdn events
The following configuration needs to be added to the router to enable logging to a syslog server,
service timestamp log datetime msec
service timestamp debug datetime msec
service sequence-number
no logging monitor
no logging console
no logging rate-limit
no logging queue-limit
logging
logging trap debug
449
