11-24-2007 09:24 PM - edited 03-13-2019 04:44 PM
Hi, we have a 6 of VIC2-4FXO, 4 of them are connected to HWIC slot from 0 to 3, it has amber lights on, while the 2 of VIC2-4FXO are connected to NM-HD-2V module that is attached to the 4 big slot, it has lights off. Is it normal like this or the lights should be off or on? please help. Thanks.
11-25-2007 07:47 AM
Are the ports working ?
Do the light turn on when the lines is being used ?
If so, it can be a just cosmetic issue, that you can ignore or discuss with the TAC, but it's possible that for a cosmetic issue, no much action will be taken by Cisco.
11-26-2007 10:28 PM
What model # router is this? Do the ports show up in a the running configuration?
-brad
