09-23-2003 02:12 PM - edited 03-13-2019 01:45 AM
Is there any way that I can determine if ToS is being used on packets using the debug features of router based IOS? If not, what else could I use?
Diego
Solved! Go to Solution.
09-23-2003 09:43 PM
Diego,
Are you using a LLQ CBWFQ policy? Typically you would need to for voice. If so a "show policy interface X/X" would show the counts for the queues.
To simply test for TOS bits, you could use an access list to match on TOS, apply it as an access-group on the appropriate interface, then show access-list to see the counts.
access-list 101 permit ip any any tos 5
access-list 101 permit ip any any tos 3
interface e0/0
ip access-group 101 out
show access-list 101
09-23-2003 09:43 PM
Diego,
interface e0/0
09-24-2003 05:14 AM
I had no idea I could use the tos parameter in an ACL. I am only used to using eq www and eq telnet. I guess that I should use the ? command more ;)
Diego
