ViewMail w/o LF components?
Is there a version of the ViewMail client that installs w/o the Lightning Fax components? It's conflicting with another fax installation.<br><br>Also, if you install Outlook and ViewMail on the Unity server, then remove it. It kills the AvSecurityKey.dll and the Sxsomething.dll, which kills Unity.<br><br>Brent<br><br>
1 REPLY
Anonymous
N/A
Re: ViewMail w/o LF components?
No... VMO is hard coded to install the print driver to convert stuff to TIFF files. It's just a print driver, I'm not sure how it could be conflicting with anything... that's strange.
I'll report the install/uninstal on the Unity server scenario to the QA folks. The VMO app doesn't have any need to be putzing around with the security key files, not sure why it'd be removing it. Probably some install shield goofiness.
Jeff Lindborg
Unity Product Architect/Answer Monkey
Cisco Systems
jlindborg@activevoice.com
http://www.AnswerMonkey.net (new page for Unity support tools and scripts)
120
