ViewMail
Installed ViewMail on an NT4 workstation running Outlook 2000. Install displayed no unusual comments; accepted all defaults. Everything seemed to work after install. However, the next day user reported error message when trying to open emails- "The file urlmon.dll is not in the specified path, you must reinstall Outlook." After clearing this error comment, Outlook hangs and must be shutdown. Tried reinstalling Outlook to no avail. <br>Have not encountered this problem with VM running on other NT boxes. The only configuration difference that I can find is that the problem WS has two HDs and Outlook is installed on the D: drive not the default C:.<br>Also tried to uninstall VM via it's uninstall app, but the program fails halfway thru. <br>Advice? Insight? Help?<br><br>
1 REPLY
Anonymous
N/A
Re: ViewMail
Had the same problem. If memory serves me correctly a Re-install didn't work for me but a Tools > Repair Outlook did.
128
