VM Forward Issue
I currently have a QSIG trunk connected to our Nortel PBX, and when calls are forwarded to Voicemail from the MGCP gateway, the calling number is being truncated to 4 digits. I am trying to track down where this might be occuring and any suggestions would be greatly appreciated. Attached is a copy of a 'debug isdn q931' which shows the truncation.
PLEASE DISREGARD: Found the problem in a Calling Party translation that was put in for the Pilot VM Number.
Hall of Fame Super Silver
Re: VM Forward Issue
Look at "Significant Digits" parameter on the GW configuration in Callmanager, if it's set to 4 then that is the issue. You cam change it to whatever you want or All digits.
Chris
Actually, i found the problem:
It was in a Calling Party translation that was put in for the Pilot VM Number.
thanks.
92
