VMO and Citrix
Our client is building a data center that is being deployed with Citrix clients. This would mean that all desktop applications will reside on the Citrix server including Microsoft Outlook. Is the ViewMail integration with Outlook<br>client supported over Citrix? <br><br>I suspect playback over the PC is not possible, but would playback over the phone work?<br><br>Also, if multiple sessions are using VMO on the Citrix server, would this cause issues?<br><br><br><br><br><br>
1 REPLY
Anonymous
N/A
Re: VMO and Citrix
It's not TAC supported but several sites have got it to work... search on the forum for Citrix and you'll find several folks discussing it. Yes, you will likely have to use the phone for recording/playback in this scenario although I think someone mentioned they found a work around for the local media device issue.
Jeff Lindborg
Unity Technical Lead/Answer Monkey
Cisco Systems
lindborg@cisco.com
http://www.AnswerMonkey.net (new page for Unity support tools and scripts)
151
