VoATM call dropping
mkoci
I'm having problems with calls dropping after 3 minutes. I'm using 3810's connected to 8510's and have the voice setup on SVC. I was running Frame-Relay and didn't have problems with voice till I moved to ATM. Has anyone else had problems with SVC's. I thought it could be the clocking since I'm getting it from the 8510 instead of the Telco, but network clocking isn't my strong point.
lisa.hall
Level 2
Level 2
You might want to start off by checking out these troubleshooting papers at http://www.cisco.com/cgi-bin/Support/PSP/psp_view.pl?p=Internetworking:VoX:VoATM. If that doesn’t help I’d suggest getting the debugs and opening a case with TAC.
