I´m having a problem with my calls going to the PSTN.
Our curtomers complain that the sound level is very low and they can´t hear us properly.
We are using CM 3.0(11), 3640 with E1 (NM-HDV1E1-30).
The IOS is 12.2.2T ( we also have tested a few other)
voice-port 1/0:15
translate called 1
output attenuation 12
echo-cancel coverage 24
no vad
cptone AT
description Voice E1 Line
The problem could be that the output attenuation 12 doesn´t have any effects - no changes if we change the dB value.
Has someone a solution for that ?
Markus
