voice card not appaering in configuration?
we have inserted pvdm3 module in to the 2901 router
but its LED status is showing Amber continuolsly.
I would like configure the VIC3-2FXS/DID card but I am not able to see the card in running configuration but I could see the card in sh diag.
Can any ony help?
Its sh diag command giving the following output.
/#sh diag
Slot 0:
        C2901 Mother board 2GE, integrated VPN and 4W Port adapter, 4 ports
        Port adapter is analyzed
        Port adapter insertion time 00:58:11 ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC16310CSA
        Hardware Revision        : 1.0
        Part Number              : 73-11834-09
        Top Assy. Part Number    : 800-30795-05
        Board Revision           : A0
        Deviation Number         : 0
        Fab Version              : 03
        Product (FRU) Number     : CISCO2901/K9
        Version Identifier       : V05
        CLEI Code                : CMMHB10ARA
        Processor type           : C1
        Chassis Serial Number    : FGL16312126
        Chassis MAC Address      : 6073.5c26.7440
        MAC Address block size   : 72
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 36 33 31 30 43 53 41 40
          0x10: 06 17 41 01 00 82 49 2E 3A 09 C0 46 03 20 00 78
          0x20: 4B 05 42 41 30 88 00 00 00 00 02 03 CB 8C 43 49
          0x30: 53 43 4F 32 39 30 31 2F 4B 39 89 56 30 35 20 D9
          0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 48 42 31 30 41 52
          0x50: 41 09 C1 C2 8B 46 47 4C 31 36 33 31 32 31 32 36
          0x60: C3 06 60 73 5C 26 74 40 43 00 48 C4 08 00 00 00
          0x70: 00 00 00 00 00 F3 00 65 40 01 25 41 00 87 42 00
          0x80: 00 F8 00 28 03 E8 1C 89 07 D0 20 21 0B B8 20 93
          0x90: 0F A0 21 2F 13 88 21 83 17 70 21 A8 1B 58 21 B0
          0xA0: 1F 40 21 AB 23 28 21 79 27 10 21 78 41 01 1D 42
          0xB0: 00 00 F8 00 28 03 E8 1C 20 07 D0 1F 40 0B B8 20
          0xC0: 6C 0F A0 21 34 13 88 21 34 17 70 21 98 1B 58 21
          0xD0: 98 1F 40 21 98 23 28 21 34 27 10 21 34 FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        PVDM Slot 1:
        16-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
        Part Number              : 73-11576-03
        Board Revision           : C0
        Fab Version              : 03
        PCB Serial Number        : FOC162257KD
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM3-16
        Version Identifier       : V01
          0x00: 04 FF 40 05 D8 41 01 00 82 49 2D 38 03 42 43 30
          0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 36 32 32
          0x20: 35 37 4B 44 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 8F 50 56 44 4D 33 2D 31 36 20 20 20 20 20 20 20
          0x40: 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 0:
        3rd generation - FXS DID Voice daughter card (2 port)
        Top Assy. Part Number    : 800-30501-02
        Board Revision           : A0
        Fab Version              : 07
        PCB Serial Number        : FOC1350420M
        RMA History              : 00
        Product (FRU) Number     : VIC3-2FXS/DID
        Version Identifier       : V02
        CLEI Code                : IP9IAB3CAB
        Longitudinal Calibration : 01 10 10 4F 8D 10 10 8F
                                   9F
          0x00: 04 FF 40 06 21 41 01 00 C0 46 03 20 00 77 25 02
          0x10: 42 41 30 88 00 00 00 00 02 07 C1 8B 46 4F 43 31
          0x20: 33 35 30 34 32 30 4D 03 00 81 00 00 00 00 04 00
          0x30: CB 8D 56 49 43 33 2D 32 46 58 53 2F 44 49 44 89
          0x40: 56 30 32 20 D9 02 40 C1 C6 8A 49 50 39 49 41 42
          0x50: 33 43 41 42 D3 09 01 10 10 4F 8D 10 10 8F 9F FF
Embedded Service Engine 0/0 :
  Total platform memory : 524288K bytes
  Total 2nd core memory : 0K bytes
  Start of physical address for 2nd core : 0x80000000
  Virtual address start of 2nd core memory : 0x0 - 0x0
  2nd core configured disabled
  L2 cache ways for 2nd core : 0
Its sh running-conf command giving the following output.
/#sh running-config
Building configuration...
Current configuration : 1228 bytes
! Last configuration change at 06:29:29 UTC Fri Feb 7 2014
version 15.1
hostname /
boot-start-marker
boot-end-marker
enable secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
no aaa new-model
no ipv6 cef
ip source-route
ip cef
license udi pid CISCO2901/K9 sn FGL16312126
hw-module pvdm 0/1
username cisco
interface Embedded-Service-Engine0/0
no ip address
no ip route-cache
shutdown
interface GigabitEthernet0/0
ip address 172.169.2.152 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password cisco
login
transport input all
line vty 5 15
password cisco
login
transport input all
scheduler allocate 20000 1000
end
and sh flash giving me the following output.
/#sh flash
-#- --length-- -----date/time------ path
1     74503236 Jul 30 2012 20:08:54 +00:00 c2900-universalk9-mz.SPA.151-4.M4.bin
2         2903 Jul 30 2012 20:21:54 +00:00 cpconfig-29xx.cfg
3      3000320 Jul 30 2012 20:22:10 +00:00 cpexpress.tar
4         1038 Jul 30 2012 20:22:18 +00:00 home.shtml
5       122880 Jul 30 2012 20:22:26 +00:00 home.tar
6      1697952 Jul 30 2012 20:22:40 +00:00 securedesktop-ios-3.1.1.45-k9.pkg
7       415956 Jul 30 2012 20:22:54 +00:00 sslclient-win-1.1.4.176.pkg
  • Other Collaboration Voice and Video Subjects
can you also post the output of the "show inv" command?
What kind of an IOS image is that? I believe it's missing a feature set, perhaps.
G.
Thank you Gergely Szabo,
Sh Inv output and sh version output is as follows.
/#sh inv
NAME: "CISCO2901/K9 chassis", DESCR: "CISCO2901/K9 chassis"
PID: CISCO2901/K9      , VID: V05 , SN: FGL16312126
NAME: "3rd generation two port FXS DID voice interface daughtercard on Slot 0 SubSlot 0", DESCR: "3rd generation two port FXS DID voice interface daughterca"
PID: VIC3-2FXS/DID     , VID: V02 , SN: FOC1350420M
NAME: "PVDM3 DSP DIMM with 16 Channels on Slot 0 SubSlot 5", DESCR: "PVDM3 DSP DIMM with 16 Channels"
PID: PVDM3-16          , VID: V01 , SN: FOC162257KD
NAME: "C1941/C2901 AC Power Supply", DESCR: "C1941/C2901 AC Power Supply"
PID: PWR-1941-2901-AC  , VID:    , SN:
/#show version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 20-Mar-12 18:57 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
/ uptime is 3 hours, 22 minutes
System restarted at 08:40:55 UTC Mon Feb 10 2014
System image file is "flash0:c2900-universalk9-mz.SPA.151-4.M4.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2901/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FGL16312126
2 Gigabit Ethernet interfaces
1 terminal line
2 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2901/K9          FGL16312126
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            None          None           None
data          None          None           None
Configuration register is 0x2012
still not sure about that IOS version.
Can you upgrade your IOS? Perhaps to a 15.3 T train?
G.
I have relaoded the IOS with the working 2901 router IOS(Which is having the similar hardware i.e PVDM3 and VIC3-2FXS/DID card) but still I am not uanble to see the voice card in  running configuration.
Bronze
Looks like you are missing the uc (voice) license.
uc            None          None           None
data          None          None           None
553
