Voice Card & PA System
Just wondering if anyone has tried using a Voice Card to implement a legacy Public Announcement(PA) system for IP Telephony/Unity?<br><br>
Gold
Re: Voice Card & PA System
We have had cases in TAC with FXO/FXS ports to an overhead paging system...
If you can dial out the line, and the paging system will pick up the call, then CallManager can integrate with it.
Keith
Keith Chambers
Customer Support Engineer
Cisco Systems
keithc@cisco.com
Anonymous
N/A
Use either FXS or FXO port on any Cisco equipment, you'll need to purchase the adaptor (Bogen part #TAMB), and you're paging will work just fine. Multi zone, or multi port.
Cheers!
John.
169
