Voice Gateway for Small Site
For an office of 10 people what would be the best Voice gateway to use?
Also what would be the best PSTN connection? A Partial PRI ?
Currently this office has 8 analog copper trunks coming into a small pbx.
With that many copper trunks I don’t think FXO cards will work…
Re: Voice Gateway for Small Site
hi jeff -
it depends on a few things. Are the 8 trunks currently enough, or too much? Also, what version of CM are you running? I believe with CM 3.2 and newer, it supports the new analog module for the 2600 (NM-HDA) which will support your 8 analog trunks.
see:
http://www.cisco.com/en/US/partner/products/hw/routers/ps259/products_tech_note09186a0080094aba.shtml
Ok the users are saying 8 is not enough... They are wanting all 10 people to be able to dial out at one time... If that is the case what are we looking at...
well you could go two ways.
1) (not so good ) you could use the 2600 solution and then purchase a VG200 with some FXO ports.
2) (better option) Use the 2600 and get the NM-HDV-T1 module. This module will take in a T1 and you could do a fractional T1 if its cost effective for your situation (otherwise just purchase a full T1).
-Jaret
204
